Parallel loop?
6 Jan 2013
Rollergirl
See attached photo of current set-up. One 980 under water, and one on air. I'll be fitting a block on the bottom card soon, and for ease I could simply take a straight tube from each blanked off port on the top card, and connect to the bottom just like I've shown in the second picture.
Will this work?
I could also re-route the Res return via the bottom GPU to keep everything in series, but I really don't think it'll look as good?
For anyone interested, I added the second card as per the image (parallel) and they both sit at the exact same temperature. A couple of degrees above ambient when idle, and maybe around 45 degrees during heavy gaming sesh.
Perfect!
Sorry to burst your bubble but the fluid dynamics means the second card would see next to no flow in that setup. You need it in a Z pattern so the distance in the loop for each card is equal.
Going on the pictures you've posted.
You've the inlet on the 1st card on the top-right, so you would need the exit on the 2nd card to be on the bottom-left. With either bitspower white rotary or monsoon though you could do it with minimal changes to your loop.
This is incorrect, according to EK waterblocks installation manuals for their parallell bridges, which would be the same as your connection:
http://www.ekwb.com/shop/EK-IM/EK-IM-3831109868065.pdf
Also, you can check the 8pack build in this forum, which is doing exactly this, but with four cards instead of two:
http://forums.overclockers.co.uk/showthread.php?t=18662538
Here's the graph for idle...
And here's the graph for full load...
As you can see, they are literally +/- 1C.
Here's the full size images...
So, how come my second card isn't getting hotter than my first?
Your method of plumbing will cause the lower card to get less flow than the top card, the thing with flow however is it has diminishing returns. Once you have enough/optimum flow then more doesn't do anything, it appears that in your setup both cards have "enough", the fact the top card is going to be getting more simply means it's overkilled more.
I've turned my D5 speed setting down from 5 to 2, and they're still +/- 1C.
Surely the difference in flow will be minimal? To my simplistic mind the flow rate will be a function of resistance (likening it to current in parallel resistors in an electrical circuit) and the resistance of the 2 blocks is going to be roughly equal. The only difference will be the slight extra restriction of the connection to the 2nd card.
One question I have though... what is that connection that appears to come off the bottom of the 2nd card?
