First time at Overclocking a Haswell based CPU, so how does this look to you guys?
First, stock voltage for my Chip is 1.024.
I'm currently at 4.4Ghz @ 1.173 Volts - load voltage while using Realbench 30 minute test.
Max temperature via HWMonitor is 63* on two of the Cores and 59* on the other two.
Does this look ok?
And, there is quite a big jump in voltage between 4.3 Ghz and 4.4. 4.3 will run 30 mins of Realbench at 1.109v. Is it normal(ish) for that?
Thanks guys
Does this look ok?
Thanks guys
