New to haswell and gigabyte z97 overclocking lots of questions
Cant find a beginners guide on here that tells you about the basics of what to turn off or on or what does what on the Z97 gigabytes.
so confused by this bios haven't upgraded since 1156
#1 what the hell is performance upgrade ?
#2 what is cpu base clock and what should it be ?
#3 what is cpu upgrade ?
#4 what is cpu clock ratio (confused as there's another on another bios page which I'll get to).
#5 proc graphics clock 1100 ? is that correct if not what should that be set to ?
like below why is there another cpu ratio on another page is it the same thing as cpu clock ratio in above pic ?
what is uncore ratio ?
#5 how to set the cpu vcore to say 1.3v the voltage doesn't change on screen when you change the voltage what + would make it 1.3 vcore ?
And I presume turbo is maximum load line calibration ?
why does it say my ram is set to 1.5 volts when it's set to 1.65 by xmp ? should I be changing this value to 1.65v ?
so basically which of these settings should I use to say set a g3258 to 4.5ghz
cpu clock ratio or uncore ratio ?
