Hi guys,
Im guessing this is probably a popular question, so I'll give you my use case and situation.
My rig =
4790k (running stock, may overclock later)
16gb 2666mhz trident x
Gtx 970
Z97 asrock extreme 6
Superflower leadex gold 650w psu.
80% of my gaming is playing csgo competitively(not pro lol, just for fun) My setup is built around csgo. And it is my main hobby. The main point of my setup is to run csgo at 300+ fps on my 144hz 1080p benq. My current build does this perfectly. (i run everything on low at 960 4:3 stretched). And the game is super fluid and responsive.
You probably thinking why would i need 970 sli or 980?
Well i want to get into playing all the latest titles at max settings at high frame rates and eventually at higher resolutions (might invest in 1440p monitor) but i defo want to try out DSR on my 1080p monitor, like 1440p and 4k DSR. So basically i want the horse power to hit high frames on max settings at 1080p or power high resolutions at max settings.
So i was wondering should i sli 970 or get a single 980?
I only game on a single monitor, even when i get 1440p one il use only one at a time, using my 1080p one for csgo and 1440 for everything else.
My main concern putting me off sli, is people claim it can cause problems and stuttering. This would be a big problem for me in csgo. Is this true?
I also heard i could just run one gpu when sli is an issue, so i could just set csgo to run on one gpu only. Does anyone know if this solves the issues and how severe issues with sli 970s are?
At the moment I'm leaning towards getting a single 980 like a classified or hof and getting a second in a year or so. Mainly because i wont have to get a new psu right away. (il upgrade to 850w+ if i sli 970 or 980). Also is 650w enough for a single 980?
I'm also concerned about heat on the 970 sli. I have a arc midi r2 with stock case fans.
Im thinking single gpu will be more reliable for csgo and run a lot cooler.
The pros for the 970 sli I'm seeing, is it vastly out performs the 980 on games where sli works. And a 980 doesn't seem to be a major improvemnt on a 970.
I appreciate this is a ramble, so im happy to clarify anything. Thanks for any help you can offer!
My rig =
Gtx 970
