- 11 Mar 2015
- Nottingham
Hi everyone,
I have just bought a 2005 e90 330i SE with 52k miles after selling my previous 2002 e39 520i. When I was driving in France in the rain at 90-100mph, I felt a fair bit of vibration in the steering wheel and through the seats - which was far more than I would experience with my previous e39 on the same roads at similar speeds and weather conditions.
The most likely culprit IMO is the woeful tyre combination the previous owner had: driver side rear - a random Chinese non-rft tyre
, passenger rear - Nokian RFT, driver front - Michelin RFT with only 2-3mm left and passenger front - another random Chinese non-rft tyre
. My e39 was shod with Continental contipremium contact 2 with around 5mm left all round when I sold it. I think it is likely that the vibrations at high speeds in low traction conditions probably results from the awful tyre combo than to a steering/suspension issue. What does amaze me though is how beautifully it rides in town; I went on the speed humps I'm used to at the same speed as my old e39 and was surprised by how more structurally stiff the e90 feels. Even handling at normal speeds in the dry is better (I can take corners at higher speeds and the whole car feels to nimble and makes the e39 feel like a boat in comparison). I can only imagine how even nicer it will be once I replace the tyres with proper ones.
I wish to buy 4 new tyres for the car and have been searching the web for magazine reviews and forum posts about tyre choice. I've pretty much decided on going for Michelin, Continental or Goodyear as they seem to be the best tyres around. Although I've read several posts about RFTs having a harsh ride and cause issues with tramlining, others seem to claim that latest RFTs have largely overcome these issues and are comparable to their non-RFT counterparts.
I would therefore appreciate your opinions on what would be the best choice for my car. My current wheel size is 225/45/17 and my priorities are wet and dry handling/braking, high speed stability (I will be going to Germany next week and will max out the car - 155mph!) and ride comfort (most of my driving is around town with potholes and speed humps). I'm not fussed about tyre longevity/fuel economy (except if they are subpar - as long as they last 10kish miles that's fine).
I would also appreciate some feedback on the choice of RFTs vs non-RFTs (latest generation). As I mentioned above, I have already searched for this on several forums and most of the posts tend to be for older RFTs. If RFTs can offer similar handling and ride comfort as non-RFTs, I don't mind paying the price premium for them, but if they still have harsh ride and tramlining issues then I will stick to non-RFTs and get a BMW mobility kit (compressor and sealant).
In summary I need the following advice:
1. Run flat or not.
2. Which brand is best for handling/high speed tolerance/ride comfort - Continental, Michelin or Goodyear.
I have been trying so far to compare tyres using the EU labelling, but, like many standardised comparisons, they only show part of the picture (e.g. only tyre noise, but not about ride comfort).
Many thanks,
Sam
. My e39 was shod with Continental contipremium contact 2 with around 5mm left all round when I sold it. I think it is likely that the vibrations at high speeds in low traction conditions probably results from the awful tyre combo than to a steering/suspension issue. What does amaze me though is how beautifully it rides in town; I went on the speed humps I'm used to at the same speed as my old e39 and was surprised by how more structurally stiff the e90 feels. Even handling at normal speeds in the dry is better (I can take corners at higher speeds and the whole car feels to nimble and makes the e39 feel like a boat in comparison). I can only imagine how even nicer it will be once I replace the tyres with proper ones.I wish to buy 4 new tyres for the car and have been searching the web for magazine reviews and forum posts about tyre choice. I've pretty much decided on going for Michelin, Continental or Goodyear as they seem to be the best tyres around. Although I've read several posts about RFTs having a harsh ride and cause issues with tramlining, others seem to claim that latest RFTs have largely overcome these issues and are comparable to their non-RFT counterparts.
1. Run flat or not.
Many thanks,
Sam
