Fixed the praxis mods button, the pin that sticks out on the picture, that is supposed to anchor the bottom half of the button on by sitting in a groove, it wasn't sticking out far enough, and unlike on a authentic praxis mod, it didn't have a hole in the other side of the switch to adjust it, so I had to drill a hole, then found out that the pin was too short full stop
So I drilled the whole lot out, and stuck a small bolt/screw kinda thing through that I found in the shed, tightended it up, now the buttons fixed fully, sorted. working perfectly like it should. so im happy with it now.
So now its fully working, this mods great, its as light with a battery in as a nemesis without a battery or a rda sat on it, its really light. and Christ does it hit hard!
