Multiple Monitors
26 Nov 2009
I need some advice please. I'm looking for the cheapest amd/nvidia cards to support triple monitors. One monitor has display port, HDMI, DVI and VGA and the other two have HDMI, DVI and VGA.
What resolution are the monitors and what games do you play, you can get a cheap card to do eyefinity or surround but on GTAV they would probably be useless?
Does your motherboard gave any graphics outputs on it? Every GPU produced in the last 10 years can output to 2 monitors, but only newer/more expensive ones can do 3. Cheapest way therefore is to run two screens from one GPU and the third screen from the onboard.
Unless you're gaming, in which case you'll need a decent GPU to run games on 1 screen and output to 2 others, or a very beefy GPU to play a game across all 3.
I'm already doing two monitors with a 560Ti but need to add third. There will be no gaming on this pc just watching flash player videos on one monitor and simple work stuff on the others. One is 1920x1200 and the others are 1920x1080. Sorry, I don't have onboard gpu because the cpu is FX8350.
If you're not planning to game, and its for general windows use, a basic AMD 5450 is all you need. You'll need an active mini-displayport to DVI adaptor, for another £20 or so, for one of the monitors.
If you have two graphic card slots in your PC, you could buy any two of the cheapest graphic cards (5450 is still a good choice) and connect 2 of your monitors to one of them and one to the other. That way you dont need a DP to DVI adaptor.
I have that card lying around. Why would I need an mini-displayport to DVI adaptor? Could I not just connect with HDMI, DVI and VGA?
The AMD 5xxx and 6xxx series only supported two monitors on DVI/HDMI/VGA, any additional monitors needed to be on the DisplayPort output (although an Active adapter on the DP output works fine). The problem you would have is finding a 5450 with a DP output - I've only ever seen them with DVI/VGA/HDMI which means only two can be used at once.
The AMD 7xxx series and above can power three or more monitors on DVI/VGA/HDMI provided they're the same model of monitor (or are compatible enough for the card to use the same clock generator for all three, which pretty much means identical monitors), or you can use the DP output for the third/fourth monitors just like the earlier generations.
Nvidia can only power two screens on Fermi architecture, but can power three on Kepler and Maxwell. This means you could go for any 6xx, 7xx or 9xx card with the right outputs, provided the card isn't a Fermi rebrand (if going for a 6xx series card, check http://en.wikipedia.org/wiki/GeForce_600_series and avoid any GPUs with code names starting GF).
Alternatively, if your motherboard support two GPUs and you're not planning on running a game in Eyefinity/Surround, you can pop pretty much any two in run two screens from one and a third screen from the other, just don't run the cards in Crossfire/SLI. You can even mix and match an AMD card with an Nvidia one if you fancy! Or, if your motherboard/CPU supports it, run two screens from a GPU and the third from the onboard.
My monitor Dell U2410 has a normal displayport, not mini, so will I also have to get a mini-displayport to displayport adaptor?
My HD5450 only has HDMI, DVI and VGA. Does that mean I can't do an extended triple monitor with that card?
Strangely the specs on the amd site say its got a Display Port as well,
Integrated dual-link DVI output with HDCP11
Max resolution: 2560x160012
Integrated DisplayPort output
HDMI® (With 3D, Deep Color and x.v.Color™)
Max resolution: 1920x120012
Integrated VGA output
Max resolution: 2048x153612
But I can't see it on the picture
http://www.amd.com/en-us/products/graphics/desktop/5000/5450#
Edit :
And this review says the HD5450 can do Eyefinity (which uses a DisplayPort)
Eyefinity is the marking name for a feature that will definitely appeal to many potential buyers, and the Radeon HD 5450 is perhaps most attractive to non-gamers with a practical need for a triple-monitor setup
While Eyefinity is a fantastic tool, and we're glad to see it up and down ATI's Radeon HD 5000-series, it does have a couple major drawbacks in a budget-oriented environment. The most significant restriction is mandatory DisplayPort use. In a triple-display setup, at least one monitor must use the card's DisplayPort output
http://www.tomshardware.co.uk/radeon-hd-5450,review-31803-3.html
It's highly up to the vendor on what monitor ports the card has. I remember there being Eyfinity editions of a few low end AMD cards but they're very hard to come by now.
To OP, I would say jus insert the 5450 into a second PCIe slot in your PC, install the drivers, and connect it to the 3rd monitor in any way you like, it will run fine in extended mode.
