- 25 May 2011
I know they do kardean which can look like wood. Am after a high gloss finish that looks like a tile but isnt. Tiles are just to cold.
Possible?
Possible?
Gloss finish anything on a floor always looks slippy to me!
Is under floor heating an option?
Could always go for a nice wood floor which has been lacquered?
You get other makes now that are a bit cheaper than Amtico.
Karndean and Polyfloor are two that come to mind.
You can polish concrete. Would achieve a high gloss finish. Get whoever lays it to print 'edges' to give the tile look and then polish at the end.
Price per square metre mostly. I've not looked at Polyfloor before though.
Your subfloor needs to be perfect when laying as you will see any imperfections when the sunlight is on it.
Laid perfectly, it does look fantastic albeit expensive.
Does underfloor heating run on electric? Is it expensive to run and buy?
Thanks for the advice. I assume this is the same for laminate planks? For reference it's a new build with floating floors.
I want hard flooring in hall/lounge, but as it's my first flat and I doubt I'll be there for the long term I don't really want to go for real/engineered wood.
