- 30 May 2012
Hi OcUK,
This may be an attempt at the impossible but here's what I'm attempting to figuring out.
My PC is at the opposite side of the house to the TV, So to use a HDMI cable between them I'm looking at 30-40 meters. So far I've only found some very expensive claiming cables that'll work at that range or to be buying 15m cables then a booster box and repeat until I reach the TV, would you know a better solution? (I'm using a MSI GTX 970 so I only presume that using the HDMI would be treated as a 3rd monitor which is perfectly suitable)
If by some miracle you guys are able to help and I can use the TV as a 3rd monitor, the next problem would be. Would a wireless keyboard and mouse manage to reach the distance or is having walls in the way pretty much a no no?
Thank you in advance to anyone who's able to help.
