All this power and nothing to show for
This ^
You should try 1440p. Grab a ROG Swift ;) i think that would be the sweet spot for your 780ti's in SLI
Can confirm that the Swift is a great match for a couple of Ti's. I really should have kept my Ti's, but the Titan X seduced me from afar. Would say the TX is a bit less powerful in games where VRAM isn't pushed over 3gb. Unfortunately many games these days at high settings appear to be using more and more VRAM.
Yep, should have upgraded the screen too. GTX 780 Ti in SLI on 1080p is a waste.
Up the MSAA to X8 then tell me it's a waste.
I ran my Titan Blacks @ 1080p for a while and I had to use maximum MSAA to offset the jagglies from 1080p on a 27" monitor and I can tell you it guzzles VRAM and works the cards really hard.
Ever heard about 3d Vision or VR ?? For gaming in 3D your SLI its almost enough to turn msaa on ultra settings.
