Verbatim Store 'n' Go 1TB Portable External Hard Drive USB 3.0 Black (53023) @ £37.98 inc VAT
Features:
USB 3.0 Super Speed data transfer
Transfer documents and data easily between home and office
Safely back up and store all your files from your PC or laptop
USB plug 'n' play (no additional power required)
Stylish slim design fits neatly onto your desk top and allows it to be transported easily
'Nero BackItUp Essentials' software - create your own 'back up' from your PC/Laptop hard drive to your portable hard drive
Quick Start Guide printed in 27 languages
The Verbatim Store n Go portable hard drive features high performance storage using a USB 3.0 “Super Speed” interface. USB 3.0 offers up to 10 times faster data transfer rates than USB 2.0 (based on USB bus speed) providing ultra fast data transfer on the go.
Store and carry your digital and day to day working files on this truly mobile drive. Its stylish smooth design sits neatly on the modern desk top as the perfect accompaniment to your laptop.
Store n Go portable hard drive is USB 3.0 bus powered (1 x USB 3.0 interface) yet is backwards compatible to any USB 2.0 ports on your PC or notebook. The drive requires no external power for operation; simply plug n play.
Store 'n' Go Portable Hard Drives are formatted in FAT32 enabling you to use them on Windows OS and Mac OS systems.
For added security Nero BackItUp Essentials software is provided to help back up your laptop or PC's hard drive. BackItUp Essentials provides an application to back up all your files, folders, and drives whenever you want, or schedule the auto back up to a set time for added security.
Nero BackItUp Essentials Software is compatible with Windows XP, Vista, Windows 7 and Windows 8 (not compatible with Mac OS).
Verbatim Store 'n' Go Portable Hard Drives also comes with Green Button energy saving software. Green Button software suspends the hard drive from spinning while not in use increasing efficiency and saving energy.
There are 3 'Sleep Setting' options. Set the suspend mode to come in after 10 minutes of use, or by increments of 10 minutes up to 120 minutes. Set the drive to suspend immediately by double clicking the Green Button icon on the desktop, alternatively you can set the drive to 'Never Suspend the disk'
Only £37.98 inc VAT.
ORDER NOW
________
Asus PCE-N15 300Mbps 802.11B/G/N Wireless PCI-E Network Adapter @ £17.99 inc VAT
Asus PCE-N15; Wired; PCI; RF Wireless; 300 Mbit/s; IEEE 802.11b;IEEE 802.11g;IEEE 802.11n; OFDM
PCE-N15 300Mbps 802.11b/g/n Wireless PCI-E Adapter
WPS(Wi-Fi Protected Setup) button - Quickly set up a secure wireless connection;
Software AP - Connect your notebook and game consoles to the Internet;
Supports WEP; WPA-PSK; and WPA2-PSK methods for enhanced security.
Comes with a Low Profile bracket included in the box
For quickly setting up a secure wireless connection. Press the Hardware WPS button on PCE-N15 about 3 seconds; then press the WPS button on router as well. Either you can choose to use software WPS; enabling the WPS utility in the WPS Wizard interface. And finish the setup with 3 steps
Software AP
Software AP mode allows the WLAN card to act as a virtual access point. The computer needs to be connected to a wired network using an Ethernet connection in order to provide network access to WLAN client.
Only £17.99 inc VAT.
ORDER NOW
Features:
ORDER NOW
________
Software AP
ORDER NOW
