***Official GTAV PC Thread*** [Important warning updated in the OP]
Me to, runs really well on my 7990 with the new beta drivers and it dose not sound like it's stressing the card either. My 7990 sound loads louder when playing evolve.
I have a question about soft shadows in the graphics settings, which setting should be better? soft or the AMD option? I noticed the AMD option used about 12mb less vram, but I'm not short of vram :D.
Yeh I think it is really cpu intensive so you probably are not getting 100 usage on on your 7990. I haven't been getting 100% usage on a single 980!
Still runs great though but its clear you need a powerful cpu for this game.
Few questions;
Do you need disc to play after install for a physical copy?
What are load times like with an HDD?
No, disk not required after initial installation, same for most DVD versions these days. Loading is slow for me compared to some other recent games like FC4 although if you die & click retry it loads quite fast
I think the only one who deserves rolleye treatment here is you.
:rolleyes:
Whoosh
This!
I am suprised I cannot find anything online about the Online Tutorial, all I want is a
-do this
-then do that
-then do this
-that
Your done - crack on
Seems I'm not the only one with the issue though, few threads in R* forums about the Tutorial being naff!
Few questions;
No.
Load times are actually quite good. I didn't have enough space on my SSD so installed onto a mechanical and haven't had any issues at all, even in the very fast cars driving through traffic etc. I think I may need to pick up an Xbox pad as driving with M&K can be a bit of a pain, especially in races. Might be good for a few other games.
Is the XBone pad worth it over the 360 version?
Getting pole dancing tips.
I think you need to have Lester availible in online to do a lot of things.
Still need to be able to buy a place to live. How did you do it Nex?
Damn right I am! :D
I think the last thing I did in the tutorial was bringing the car to the mechanics to get it insured etc. and that was it, once I did that, I was able to buy cars + apartment.
Looking back on the apartment, I think I should have gone for the cheaper tinsel towers instead as IIRC they are more central and closer to certain places.
Hmm, guess I will need to do some reading then BOOOOOOOOOOOOOOOOO!
yaay, im in :)
after playing the start of the game i crashed with a memory issue but i needed to stop then anyway as i could smell my 7950 getting hot, apparently it reached 102c :o
think il get the hoover on it before i play again :D
erm, yeah i suppose it was time for a clean...
:o
No.
Thanks!
And I'd say no, 360 pad is brilliant and official one can be had at <£20.
Holy... That is absolutely disgusting, how filthy is your house????
~2 years unchecked, i think my case had been sucking in more than it blew out :/
it looks brand new now though :)
EDIT: CPU cooler was almost spotless, i have a fan on the side of my case blowing air out, i think it was causing air to get sucked in from the back, through the card, then out the side,
going to change side fan to blow in instead, shoud make a difference
My son wants this for his birthday. He's only 7. I can't seem to find anywhere selling the Sega Master System version.
Any help?
ha.....ha...ha. Why are you bothering to try and troll in here? This is the 4th or 5th post I have seen from you in this thread. Get a life.
I haven't had any issues with GTA yet in terms of performance *touch wood*
Are there any trends between AMD/Nvidia cards or anything like that?
