***Official GTAV PC Thread*** [Important warning updated in the OP]
Yeh I think it is really cpu intensive so you probably are not getting 100 usage on on your 7990. I haven't been getting 100% usage on a single 980!
Still runs great though but its clear you need a powerful cpu for this game.
I have to say it's seems to run perfect on my setup, nothing seems to be pushed to it's limits. Though I would like to look at the CPU and GPU usage :)
hi guys been playing and having a great time,one question I'm level 7 and teamed up with some player for a job,they were level 7 too.they had rifles and when I go into a weapon shop all thats on sale is a pistol and some sniper rifles all locked ?am I missing something
erm, yeah i suppose it was time for a clean...
:o
Seriously? :eek:
so any advanced guides on performance for this yet and what kills FPS and what doesn't?
MSAA and Tesselation mostly.
You would also have to measure the settings in loads of different areas of the map to get a true reflection on the settings performance as well.
The extended distance scaling has little effect in the middle of the city where most of the stuff in the distance is blocked by buildings, out in the countryside though it has a big effect I find.
an i7 overclocked helps
http://forums.overclockers.co.uk/showthread.php?t=18666314
Looking at the Guru3D article MSAA can affect FPS, but for me VRAM is the limiting factor even at 1080p. There appears to be a mismatch between the game's reported VRAM usage and MSI AB's
http://www.guru3d.com/articles_pages/gta_v_pc_graphics_performance_review,9.html
What I am finding however is that if I increase some settings to v high (GFE says that these are optimal for me) I get flickering, just like what this guy gets.
http://forums.overclockers.co.uk/showpost.php?p=27915423&postcount=2494
I've been feeding all my low ranking buddies with weapons , f9 to drop weapon , f10 to drop ammo
Looks like its time for me to actually clock my 4770k.. Thanks for the links mate.
Mine was running perfect but just fired it up and I'm getting pausing when driving. It's not slow down but everything seems to slow for a second then speed up. (Rubber banding) It does it all the time..
That is exactly what my problem is
What card do you have???
What CPU and is it overclocked
Fo you gave an SSD
Also it#s not CPU spikes. I have a thread in Graphic cards with all my findings and tests
Currently re downloading it.
My install took over an hour on Tuesday morning and I am wondering if that is the issue.
I will let you know how I get on
