String - I only got GTA 5 set up yesterday. As usual I've been doing various SLI stutter tests. At first I was really annoyed as there was very apparent microstutter and judder when running SLI (but fine on one 780Ti).
Here's my findings so far:
Early testing on first getting game:
- Any sort of
MSAA applied
causes stutter with SLI. Even if only 2x MSAA, which is well within specs, and my Vram is not being over used (using 2.5GB max, monitoring it).
- Just using FXAA on its own is very smooth with SLI (but has slight blurring to the whole image as usual. I don't like FXAA)
- Using SweetFX SMAA, slight lumasharpen and a touch of liftgammagain ans subtle curve tweaks, NO MSAA in game and - Boom! All is Great with SLI
- If using a 120Hz monitor, and you have Gsync - Set the
refresh rate to 85hz in game. Stops the frame rate jumping around so much, and it is totally smooth as silk!!!!!!!!!!
This is testing in the first area once you're into the game - outside Franklin's house etc. Need to test other areas but so far I have fixed my SLI stutter for now!
