This post spans off from another post which can be found here
http://forums.overclockers.co.uk/showthread.php?t=18666519
Basically I have an A/V receiver for my 5.1 surround sound which only supports HDMI and I'm looking to upgrade to a 144hz 1440p monitor to which makes HDMI void and display port seems best.
However I will require split double output from the gpu to achieve this.
I will quote my previous post.
my A/V receiver is HDMI 1.4a but this makes no difference as its still not 144Hz nor 1440p
Seems so, I discovered this... What a poor piece of technology
Option 1)
Duplicate the display from Monitor 1 to the A/V Receiver.
How will duplicating the display effect the performance ?
Option 2)
Extend the desktop to the A/V Receiver to which will only display a wallpaper
How will this effect performance ?
there are different hdmi revisions...hdmi 1.4b can do 120hz for 1080p i understand...need to check your av receiver hdmi standard (and your monitors)
HDMI only works if video is present. Audio cannot be sent alone.
Option 1)
Option 2)
It'll literally be sending two copies of the same signal through two separate outputs. You'd get the same result from having the signal split externally via a cable. No processing power required!
