- 20 Apr 2004
- Rugby
Carrying on from the 5820k overlocking thread where I was getting very high load temps (http://forums.overclockers.co.uk/showpost.php?p=27913655&postcount=146)
So today I reseated the CPU, contact was good and just the right amount of compound being used. So I reapplied and booted her up. Yet I still have extremely high temps.
Mid to late 30's at idle at 3.8ghz and high 60's low 70'sunder prime and about 10c less on real bench :-/. Still one bit of odd behaviour. If i use the 4ghz profile on my borad (which applys a Vcore of 1.21v) idle temps are LOWER in the low 20s but still shockingly high under load (80c).
Trying the 4.4ghz profile (1.3vcore) i still get the low normal temps but as soon as you fire up prime it quickly hits the high 90's then low 100's and throttles.
So I have good contact with the CPU and waterblock and the water gets warm. So I'm relay confused in what to try next. Go to the original inserts for the block and not the ones called out in the manual for LGA2011. Could it be a faulty temp sensor somewhere, as the system is rock stable.
