- 29 Feb 2012
- London
What's a good spray paint for cars please?
Full respray in my garge
If you dont want to go solvent based, Auto Air Colours are great.
I've resprayed a car in a garage, and I've also resprayed a car outside. You can get passable results in those conditions but perfection is extremely difficult to achieve.
Yeah, cellulose in particular is relatively forgiving to work with and as long as you lay on enough coats and are willing to put in the effort you can achieve a good finish even if it's a bit rough out of the gun.yep, pretty much this - with the exception that if you really y put the time into prep and working clean then the final clearcoat finish can actually be rescued with wetsanding and polishing if it didn't go so well.
