** New Product Alpenföhn Matterhorn Black & White CPU Coolers**
7 Feb 2011
Stoke on Toast
Alpenföhn Matterhorn Black CPU Cooler @ £39.95 inc VAT
Due to popular demand The matterhorn Rev C returns as the White edition a completely white version based on the original and award winning matterhorn.
The Design of the heatsink maximises the amount of fins fitted in a relatively small area allowing for the heat dissipation of larger coolers on a much smaller footprint.
The 6 U shaped heat pipes optimise the transfer of heat from the CPU plate to the Fins
The Wingboost 2 fan new aerodynamically improved wing geometry we could not only increase the airflow but as well inprove the static pressure at lower noise.
WB2-Technology
Many users ask themselves…what are WingBoost´s? WingBoost´s are ridges on the
impeller that guide the air on the air-inlet side of the impeller. Using the WingBoost 2
technology air turbulences are reduced wich leads to a lower noise level at full speed.
S-Shape geometry
With the improved S-Shape geometry we could reach a higher static pressure compared
to conventional designs.
HD-bearing:
The new developed HD Bearing (Hydraulic Bearing) reduces friction noises to a minimum and thus enables to a quiet operation.
Heatsink Spec:
- Size: 138x123x158mm
- Weight: 657gr
Fan Spec:
- Size: 120x120x25mm
- Rated Voltage: 12 VDC
- Speed: 500 - 1500 RPM
- Airflow: 106 m³/h
- Bearing: HD-Bearing
- Auto Restart: Yes
Only £39.95 inc VAT.
ORDER NOW
Alpenföhn Matterhorn White CPU Cooler @ £39.95 inc VAT
ORDER NOW
That's not a cooler. I don't considering anything unless it's got at least 2 fans and barely fits in my case.
I was wondering why people were moaning about the price as I must have missed the original pricing how much were they trying too sell these for? I must stay that they do look ok but I prefer a AIO these days
Up for £59.99 this morning, wish I had not come back to the thread as ignoring them at £60 was easy, £40.... argh, they are so nice...
Yes I though the price looked too be spot on at the £40 mark they do look stylish I do agree but as I don't use a windowed case such things don't mean too much too me personally but its still nice too know that what is in the case does look good even if you can not see it lol
i have the rev b version of this cooler and it can kick some hyper 212 evo ass out of the park. this is a damn good cooler. the mounting system is very high quality and i have remounted this cooler over 100 times as i used it for binning some cpu's.
White and Black look fantastic. 5 degrees above a Noc if you're looking for a high end air cooler, but still good temps.
index.php
