We'll have both Windows 8.1 and Linux Ubuntu versions available. I'll keep you up to date with ETA's here. The latest news is that UK stock won't land until the second week in May.
Intel Compute Stick - Intel Atom, 32GB, HDMI, Computing Dongle - Windows 8.1 @ £129.95 inc VAT
In the office, computer lab, or at home, the Intel Compute Stick gives you the power to work anywhere there is an HDMI display
The Intel® Compute Stick is a new standard for stick computing devices that enables you to transform a display into a fully functional computer. Just plug the Intel Compute Stick into any HDMI TV or monitor, connect your wireless keyboard and mouse and you are ready to stream media, work, or play games.
The built-in WiFi and on-board storage enables you to be productive immediately.
We mean it when we say ready to go out-of-the box. A cost-efective computer for home, business, and PC-like embedded applications, the Intel Compute Stick is small enough to ft in the palm of your hand, yet big enough for a quad-core Intel® Atom processor and your choice of operating systems: Windows 8.1 or Linux Ubuntu.
The Intel Compute Stick delivers a Mini PC with full-size performance, reliability, and ease of use so you can work when, where, and how you want. It's the quality and value you've come to expect from Intel in a product designed and built by the company itself.
Anywhere you have a TV, you also have a Windows-based computer
Plug the innovative form factor into an HDMI port on a television or display, connect a wireless keyboard and mouse, and you have a fully functional, Windows 8.1- based system. The compute stick has the performance you need to stream media, edit photos and fles, or create projects.
You can store your fles locally for quick access or use the built-in wireless to access fles from your home network and from the cloud. The quad-core Intel Atom processor gives you enough performance for casual gaming and there's also a USB port to connect your peripherals
Specifications
Processor:
Intel® Atom Processor Z3735F
Supports Intel® Virtualization Technology (Intel® VT-x)
Graphics:
Intel® HD Graphics
1x HDMI 1.4a
System Memory:
2GB soldered, single channel, DDR3L memory
1.35V, 1333MHz
Storage:
32GB eMMC device built-in
SDXC v3.0 slot with UHS I-Support
Connectivity:
Integrated 802.11bgn Wireless Connection
One USB 2.0
Bluetooth 4.0
MicroSD card slot
Audio:
Intel HD Audio via HDMI, supporting multi-channel digital audio
Mechanical Size:
103mm x 37mm x 12mm
Power:
5V, 2A AC Adapter
Only £129.95 inc VAT.
ORDER NOW
Intel Compute Stick - Intel Atom, 8GB, HDMI, Computing Dongle - Linux Ubuntu @ £89.99 inc VAT
Plug, play, and produce: Linux-based computer makes collaboration at work simple
The Intel Compute Stick with Ubuntu has all the performance you need for running thin client, embedded, collaboration, or cloud applications. The compute stick makes it easy to stay productive whether you're in the office, a conference room, or moving from desk to desk in the workplace.
8 GB of onboard storage means that no matter where you go, your system and your fles are with you. And with the included micro SD card slot, you get the option of additional storage, allowing you to access even more fles quickly and easily. And you don't need to worry about theft, either. The compute stick has a security notch for securing to objects with a cable, ensuring that your device moves only when you want it to.
Specifications
Processor:
Graphics:
Intel® HD Graphics
1x HDMI 1.4a
System Memory:
1GB soldered, single channel, DDR3L memory
1.35V, 1333MHz
Storage:
8GB eMMC device built-in
Connectivity:
One USB 2.0
Bluetooth 4.0
MicroSD card slot
Audio:
Mechanical Size:
103mm x 37mm x 12mm
Power:
5V, 2A AC Adapter
Only £89.99 inc VAT.
ORDER NOW
Specifications
Processor:
Graphics:
Intel® HD Graphics
1x HDMI 1.4a
System Memory:
1.35V, 1333MHz
Storage:
Connectivity:
One USB 2.0
Bluetooth 4.0
MicroSD card slot
Audio:
Mechanical Size:
103mm x 37mm x 12mm
Power:
5V, 2A AC Adapter
ORDER NOW
Specifications
Processor:
Graphics:
Intel® HD Graphics
1x HDMI 1.4a
System Memory:
1.35V, 1333MHz
Storage:
Connectivity:
One USB 2.0
Bluetooth 4.0
MicroSD card slot
Audio:
Mechanical Size:
103mm x 37mm x 12mm
Power:
5V, 2A AC Adapter
ORDER NOW
