Philips BDM4065UC 40" 4K 60Hz Widescreen LED Monitor - Black @ £689.99 inc VAT
See the big picture with all the details. The expansive 40" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in Ultra HD. Expand your viewing experience with the monitor that is designed for the way you work.
These latest Philips screens deliver UltraClear, 4K UHD (3840x2160) pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets. Philips displays will give you UltraClear images.
Philips VA LED display uses an advanced vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 176/176 degree extra wide viewing angle, resulting in crisp images.
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturati on and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
Mobile High Definition Link (MHL) is a mobile audio/video interface fo r directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
Features:
- Expansive 40-inch class brilliant display
- UltraClear 4K UHD (3840x2160) resolution for precision
- VA display gives awesome images with wide viewing angle
- MultiView enables active dual connect and view at same time
- SmartImage presets for easy optimized image settings
- LED Technology ensures low power and natural colors
- Slim bezel design for a stylish look
- Powerful 7-Watt speakers to unleash your content
- USB 3.0 Hub for convenient access and fast charging
- SmartConnect with DisplayPort, HDMI and VGA connections
- MHL technology for enjoying mobile content on big screen
- VESA mount allows for the perfect setup
Specification:
- Display Screen Size: 40"
- Aspect ratio: 16:9
- Panel Type: VA
- Brightness: 300cd/m2
- Contrast Ratio: 5000:1 (Typ)
- Dynamic Contrast Ratio: 500,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 3ms (GTG)
- Viewing Angle (H / V ): 176 ° / 176 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB 3.0 Hub: Yes
- Speakers: Yes (2x 7W Stereo)
- VESA: 200x200mm
- Warranty: 2yr (On-Site with Philips)
Only £689.99 inc VAT.
ORDER NOW
________
Asus PG278Q ROG Swift 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red @ £559.99 inc VAT
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggering 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
The ROG SWIFT PG278Q represents the pinnacle of gaming displays, seamlessly combining the latest technologies and design touches that gamers demand.
This 27-inch WQHD 2560 × 1440 gaming monitor packs in nearly every feature a gamer could ask for. An incredible 144Hz refresh rate and a rapid response time of 1ms eliminate lag and motion blur, while an exclusive Turbo key allows you to select refresh rates of 60Hz, 120Hz or 144Hz with just one press. The ROG SWIFT contains integrated NVIDIA® G-SYNC™ technology to synchronize the display's refresh rate to the GPU. This technology eliminates screen tearing, while minimizing display stutter and input lag to give you the smoothest, fastest and most breathtaking gaming visuals imaginable. Connectivity is simple, yet robust, with a single DisplayPort 1.2 port to enable NVIDIA® G-SYNC™ and dual USB 3.0 ports for convenience.
Conventional 60Hz monitors show extensive motion blur which detracts from your gaming experience. The ROG SWIFT PG278Q Gaming Monitor with NVIDIA® Ultra Low Motion Blur technology* reduces the effects of motion blur by delivering crisp edges in fast-paced gaming environments for perceivable differences in natural movement.
ASUS-exclusive GamePlus Technology enhances your gaming experience further by providing you with crosshair overlays for FPS games and multiple in-game timers for RTS/MOBA games.
The ROG Swift has a super-narrow 6mm bezel that begs this monitor to be used in multi-display gaming set-ups. With VESA wall mount capability and an ergonomic stand designed with full tilt, swivel, pivot and height adjustments, the ROG SWIFT is ready for long gaming sessions in comfort.
The ROG SWIFT PG278Q represents the next generation in gaming displays. This WQHD 2560 x 1440 monitor delivers four times the resolution of 720p, with 109 pixels per inch or 109 RGB matrices per inch. This gives you the benefits of greater image detail and up to 77% more onscreen desktop space than standard Full HD (1920 x 1080) displays. These minor details add up to give you a major in-game advantage.
Unlock the highest frame rates available, decimate lag and say goodbye to motion blur to gain the upper hand in first person shooters, racers, real-time strategy and sports titles. With twice the frame rate of standard LCDs, the ROG SWIFT PG278Q Gaming Monitor encourages you to never blink again.
Response time and ultra-smooth gameplay are the hallmarks of a true gaming monitor. With a 1ms rapid response time – the fastest available – the ROG SWIFT PG278Q Gaming Monitor eliminates smearing, tearing and motion blur, allowing you to quickly react to your game.
NVIDIA®G-SYNC™ display technology delivers the smoothest, fastest and most breathtaking gaming imaginable. G-SYNC™ synchronizes the ROG SWIFT's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, while objects look sharper and more vibrant. Gameplay is fluid and responsive too, ensuring a serious competitive edge.
The ASUS Display R&D team works closely with NVIDIA to ensure that everything runs smoothly on ASUS G-SYNC™ monitors. The ROG SWIFT PG278Q gaming monitor with built-in G-SYNC™ delivers super smooth and stunning visuals.
The ROG SWIFT PG278Q is compatible with the NVIDIA® 3D Vision™ 1 and 2 kits* to support up to three WQHD displays for immersive multi-display 3D gaming experience. ROG SWIFT provides the finest 3D gaming and content viewing experience and thanks to the ever-growing library of over 700 3D Vision™ ready game titles, as well as 3D Blu-ray movies and YouTube 3D Playback support. See everything in a new dimension with the ROG SWIFT.
*Requires NVIDIA® 3D Vision™ kit, sold separately.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Exclusive GamePlus onscreen timer/crosshair, 60-120-144Hz refresh rate turbo key and intuitive 5-way OSD navigation joystick
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (68.47cm)
- Pixel Pitch: 0.233mm
- Resolution: 2560x1440 WQHD
- 2D mode: 2560x1440 (up to 144Hz)
- 3D mode: 2560x1440 (up to 120Hz)
- 2D Surround: 7680x1440 (up to 144Hz)
- 3D Surround: 7680x1440 (up to 120Hz)
- Panel: TN
- Response Time: 1ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1
- Colour: 16.7M (Real 8-Bit)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- 3D Vision 2.0 Enabled
- G-Sync Enabled
- ULMB Enabled (NVIDIA Ultra Low Motion Blur Technology)
- Phys. Dimension with Stand(WxHxD): 619.77x362.96x237.9mm
- Box Dimension (WxHxD): 756x456x300mm
- Weight 7.5kg
- Full Specification: http://www.asus.com/Monitors/ROG_SWIFT_PG278Q/
- Warranty: 3yr (On-Site with Asus - 01442 265 548)
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Only £559.99 inc VAT.
ORDER NOW
Features:
Specification:
- Panel Type: VA
- USB 3.0 Hub: Yes
- VESA: 200x200mm
ORDER NOW
________
Features:-
Specification:-
- Panel: TN
- USB 3.0 Hub
- G-Sync Enabled
- Weight 7.5kg
ORDER NOW
