***Official GTAV PC Thread*** [Important warning updated in the OP]
I can see myself getting another 1-2 weeks of fun from the MP side of things and that will be all I reckon.
R* really need to fix the SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW loading times and general niggles like being booted to a different lobby after races are over etc. I am willing to put up with it for now as the MP is fun but.... once that fun wears off then I CBA putting up with these issues.
I knew that we would get bored of the MP pretty quickly but I have certainly had my £20 worth of fun.
Online FPS games like bf 4/HL will always have way more longevity in them than these sort of MP games.
agree Nexus.
Someone last night, cant remember who it was now, said there is a way to remain in the same lobby as the host of the games...think its on Online Settings tab, something like remain with host or something.
agree Nexus.
Ooh, will check that out - my biggest issue is the session switching you have to do.
Yeah I will see what deals are on at the offy near work at lunchtime.
Don't worry about not being the "best" player, we play for fun.
Cider isn't a gaming drink, it's clearly all about the southern comfort and irn bru.
Playing for fun > playing for serious though.
Anyone going to be up for some heists tonight? I think I have to host the prison one so I can start to host the others :D
Absolutely up for some heists, currently doing the prep work for Humane Labs (the one after prison) and its tiresome with randoms and no voice comms
Well I'll be around tonight after chores and other general housework, so I'll hop on TS or something around 7ish and start to host the prison break and then move on if people are keen!
First week day off in a long long time, the suns gone in so its GTA. However nobody is on TS and plus GTA online keeps 'timing out' :(
doesnt sound like much fun to me, one sided game mode equals fun? I wonder what we'd do with a one sided OP mess of a game mode in BF4?
hmmmmmmmmm, I'm just of the opinion that MP really isn't hitting the spot for me, the game modes just seem to have no thought put into them. Quantity over quality it would appear, still willing to give it a go though if you say it's fun, cant be any worse than some of the other modes.
I agree Tony. Was keen to also play some BF4 this weekend.
I know I'm a bit late to the party, but my copy just arrived today and is now installing :)
Luckily mine happens to come with the bonus $1,000,000 split between online and single player, what would you recommend buying first to help get more?
Best house you can afford then I would buy the armored car as it makes the missions a lot easier and gives you some protection from other players online.
hmm, that does seem random. whenever i have teamviewer running my game starts windowed.
im sure you can add commands to a text file somewhere ill see if i can dig out where.
edit: here
Commandline parameters can be added to the "commandline.txt" file in the root of the game folder. If this file doesn't exist, you can create it by right clicking in the game install directory, select New and select Text Document. Rename this file to commandline.txt. Please see below for the various command lines that can be used:
-UseAutoSettings:
Use automatic generated settings
-benchmark:
Starts the benchmark test from the command line
-benchmarkFrameTimes:
Optionally output the individual frame times from the benchmark
-benchmarkIterations:
Specifies the number of iterations to run the benchmark for
-benchmarkPass:
Specifies an individual benchmark scene test should be done, and which test that should be
-benchmarknoaudio:
Disable audio processing for graphics benchmark purposes
-disableHyperthreading:
Don't count hyperthreaded cores as real ones to create tasks on
-goStraightToMP:
Jump straight to MP while loading
-ignoreDifferentVideoCard:
Don't reset settings with a new card
-ignoreprofile:
Ignore the current profile settings
-mouseexclusive:
Game uses mouse exclusively.
-noInGameDOF:
Disable In-game DOF effects
-safemode:
Start settings at minimum but don't save it
-shadowSoftness:
Selects between linear, rpdb, box 4x4, soft 16
-uilanguage:
Set language game uses
-useMinimumSettings:
Reset settings to the minimum
-HDStreamingInFlight:
Enable HD streaming while in flight
-SSA:
Enable SSA
-SSAO:
Set SSAO quality (0-2)
-anisotropicQualityLevel:
Set anisotropic Filter Quality Level (0-16)
-cityDensity:
Control city density (0.0 - 1.0)
-fogVolumes:
Enable lights volumetric effects in foggy weather
-fxaa:
Set FXAA quality (0-3)
-grassQuality:
Set grass quality (0-5)
-lodScale:
Set LOD Distance Level (0.0-1.0f)
-particleQuality:
Set particle quality (0-2)
-particleShadows:
Enable particle shadows
-pedLodBias:
Set Pedestrians LOD Distance Bias (0.0-1.0f)
-postFX:
Set postFX quality (0-3)
-reflectionBlur:
Enable reflection map blur
-reflectionQuality:
Set reflection quality (0-3)
-shaderQuality:
Set shader quality (0-2)
-shadowLongShadows:
Enable shadow rendering for dusk and dawn
-shadowQuality:
Set shadow quality (0-3)
-tessellation:
Set tessellation on or off (0-3)
-textureQuality:
Set texture quality (0-2)
-txaa:
Enable NVidia TXAA
-vehicleLodBias:
Set Vehicles LOD Distance Bias (0.0-1.0f)
-waterQuality:
Set water quality (0-1)
-keyboardLocal:
Sets the keyboard layout to the specified region.
-hdr:
Set the whole rendering pipeline to 16-bit
-noquattransform:
Don't use quaternion transforms for placed entities
-DX10:
Force 10.0 feature set
-DX10_1:
Force 10.1 feature set
-DX11:
Force 11.0 feature set
-GPUCount:
Manual override GPU Count
-adapter:
Use the specified screen adapter number (zero-based)
-borderless:
Set main window to be borderless
-disallowResizeWindow:
Do Not allow the window to be resized
-frameLimit:
number of vertical synchronizations to limit game to
-fullscreen:
Force fullscreen mode
-height:
Set height of main render window (default is 480)
-multiSample:
Number of multisamples (1, 2, 4, 8, or 16)
-width:
Set width of main render window (default is 640)
-windowed:
Force windowed mode
-StraightIntoFreemode:
If present the game will automatically launch into the multiplayer game in freemode.
