why are PC fan fixings/screws rubbish, its the only part of a pc where you need to use a self tapping style screw. why not some nice bolts with thumb screw style nuts. Ive just bought 2 bitfenix pwm fans, i have to say these are the worst fans for fixings i have ever seen. The plastic is a brittle perpsex and some of the screws go in ok to start with but are a real pain for the last few mm. I had stand above my pc case and push down withboth hands on a screwdriver full force to get them fully in. the case was bending under the pressure.. i weaker case probably would have bent. If you were fixing to a perspex panel or window, then you would have no chance.. so BITFENIX get your fans sorted!
ps they look pretty tho.
i have tried to used some diy bolts, but they just popped through the case holes as the heads were to small, plus they were silver.
