**TODAY ONLY! 23/04/2015** Sexy HyperX Savage Red Deals! 8GB & 16GB 2'400MHz
OcUK Staff
4 Feb 2013
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £89.99 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Only £89.99 inc VAT.
ORDER NOW
_______
Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) @ £49.99 inc VAT
Features:-
Specification:-
Only £49.99 inc VAT.
ORDER NOW
Features:-
Specification:-
ORDER NOW
_______
Features:-
Specification:-
ORDER NOW
Hi, can you confirm the timings at 2400 please, all the reviews I have found show them to be 11-13-14 not 11-11-11 except at the lower speed of 1600?
Thank you.
Would you actually notice any difference going from 8GB 1600MHz to 16GB 2400MHz
Depends what you're using the computer for.......gaming, you probably wouldn't notice much difference (unless you like having lots of programmes running in the background), but if it's high-end graphics, rendering etc then yes you would notice a difference.
This was the response I got
'In this instance it was a today only offer with a limited quantity so I couldn't give you an estimation of when or if this offer will occur again im afraid.'
I will wait I'm in no big rush and my OCD will no allow me to pay any more now. :)
