Load temps before were as you said around 60-65
now i am seeing 1 card at 36c and the other card at 43c
Resurrecting this old thread to report back & ask for opinions...
To recap: I came here seeking advice as my ASUS GTX 970 Strix was idling at 60 - 65C (pottering on web, doing email). Have tidied up the cables and added / upgraded fans wherever practical, and GPU temp is now down to circa 46C at idle (fans at 0%), so a good improvement, but still not as cool as others I read about.
I don't think I can really aircool the case any better than it is now. Room temp is around 25C (admittedly we keep a fairly warm house...).
Do you guys think there's any more improvement to be had here? The reason I'm still fussing about this is I'm still getting periodic black screen crashes when the computer's not under any harsh load (see original post). But I can't in all conscience blame it on the GPU right now as it's good as gold when my son's hammering it in demanding games. In general we've been well pleased with this card.
It's quite hard to see the wood for the trees on this one...
It would be nice to eliminate the GPU from the black screen problem though. Having done some reading elsewhere on this site, I was wondering if OCUK would continue to honour my warranty if I replaced the thermal paste (something I'm perfectly confident to do myself). Couldn't see a definitive answer on that topic, but I haven't been in touch with customer services yet either. Replacing the paste certainly seems to have had a dramatic effect for Harry5522 above, and I keep reading how this card should idle around 30C.
Thanks for reading - any thoughts?
While your Strix could run a bit cooler than that, I still doubt it's the culprit behind the crashes... the Strix will rarely idle at 30c, so don't worry. The typical idle temp for this card is around 40c so you're only 6c off the mark.
Why not just open afterburner an enable a custom fan curve? I have the msi 970 i run it at min 25% fan speeds all the time
