Mercedes Faults
20 Sep 2009
Brighton
Hi guys,
Wondering if anyone can help. I've got a 2004 Mercedes E-Class 2004 W211 that I've recently had a few issues with. I'm getting faults for ABS and ECP not working, plus it's advising an urgent brake service. This was just an intermittent fault, but now happens every time I start the car. It also means the suspension is very hard and cruise control won't activate.
I've had a look around the internet and apparently it's fairly common and can sometimes be easily fixed by replacing the brake light switch. I recently bought one, but it doesn't fit, although it says it's the correct model. This is it
However, my car only has 2 pins to plug into and not the 4 on this one. Everything else indicates it's the right model for the car, but I'm stuck as to what to do, as I can't find a 2-pin version at all. Can anyone advise please? :(
Does the dealer not have them for your model? You could always get the part number and try find them from that?
