- 7 Sep 2013
Hey guys, I'm looking to build myself a bit of a dream gaming rig after having coped with a Q6600 / GTX 580 build for way longer than I should its finally time to treat myself a bit.
I'm looking to use this for heavy gaming, streaming and some video editing with a view to future proofing as much as possible since the next time I will foreseeable be able to do a full new build again will be many years down the line (minor upgrades may be possible). I have about £2,000(ish) to spend and can prob go a maximum of £200 or so above that.
I do not need optical's since I never use them, I do not need a monitor as I plan to buy a ROG 27" as separate purchase down the line unless some of these freesync monitors turn out to be awesome?, I do not need an OS and I'm fine for storage as I intend to use the M.2 for the OS and SSDs I already own for programs I regularly use. I'm fine for Paraphernalia as I have a G600 mouse, MK-85 Qpad keyboard and a Siberia v2 headset, however I could use some speakers!
I'm happy to build the system myself and I'm looking for a nice clean finish so cable management is a thing. I have kinda put myself a build together after spending a lot of time looking at 4790k options I decided to try a overkill X99 setup but if you think you can get more for my money let me know about it!
I was going to put a H110i GT on this but they seem to have all been recalled? and given the option I would have gone with 16gigs (2x8) Kingston Fury Black's but that was not an option on the store
I cant see myself been able to afford a second 980 so that's why I went with the 5820k as opposed to the 5930k, I plan to OC a reasonable amount.
YOUR BASKET
1 x Asus GeForce GTX 980 Matrix Platinum 4096MB GDDR5 PCI-Express Graphics Card £599.99
1 x Asus Rampage V Extreme Intel X99 (Socket 2011) DDR4 EATX Motherboard £359.99
1 x Kingston Fury Black 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Black (HX424C15FBK4/32) £319.99
1 x Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K) £299.99
1 x Corsair HX750i Full Modular Digital Power Supply (CP-9020072-UK) £126.95
1 x Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler (CW-9060021-WW) £101.99
1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW) £99.95
1 x Samsung 850 EVO Series M.2 250GB SATA 6Gbps Solid State Drive (MZ-N5E250BW) £96.98
1 x Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Black £64.99
1 x MicroLab M700 40W 2.1 Speaker System - Gloss Black Finish £29.99
1 x Arctic Cooling MX-4 Thermal Compound (4g) £8.99
Total : £2,126.29 (includes shipping : £13.75).
Any help with improving the bang for the buck would be very much appreciated friends. #AmIDoingThisWrong?
YOUR BASKET
