** THE FASTEST & LOWEST PRICE DDR4 MEMORY BEAMS DOWN TO OcUK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
This memory literally does feature Beaming Technology, OcUK has established a UK exclusive on all GeIL iLUCE memory and has some extremely aggressive pricing for our launch of this absolutely visually stunning memory. It has it all, incredible aesthetics and insane performance, plus it is IN STOCK NOW:
GeIL Super Luce 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - White (GLW416GB3000C16QC) @ £215.99 inc VAT
GeILs’ latest benchmarking DDR4 hardcore gaming series – SUPER LUCE, is equipped with the patented iLUCE Thermal-beaming Technology.
User will be able to observe real-time temperature condition of memory modules through different LED breathing-light tempos, directly from the SUPER LUCE heat-spreader.
As the working temperature of memory rises, the tempo of the breathing-light goes up in five different levels, Level 1 is with the mildest tempo and the lowest temperature range of below <40 ?, while Level 5 being the most rapid with the highest temperature range of above >55 ?. The following are the different temperature ranges with the corresponding breathing-light beats per minute of the five levels:
Level 1 --> <40c: 13 beats/min,
Level 2 --> 40-45c: 60 beats/min,
Level 3 --> 45-50c: 80 beats/min,
Level 4 --> 50-55c: 120 beats/min,
Level 5 --> >55c: 200 beats/min.
SUPER LUCE is available in three different LED color scheme designs - SUPER LUCE WHITE, SUPER LUCE RED and SUPER LUCE BLUE.
These color schemes are to provide users with the flexibility of visually matching with the different high-end motherboard color schemes. Covering speeds from 2666MHz to upwards of 3400MHz, SUPER LUCE is not only the ultimate DDR4 memory that delivers eye-catching esthetics and hardcore performance. Together with the iLUCE Thermal-beaming Technology, SUPER LUCE will bring your gaming station to live.
Specification:-
- iLuce Thermal-Beaming Technology (patented)
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.20-1.35V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Only £215.99 inc VAT.
ORDER NOW
GeIL Super Luce 16GB (4x4GB) DDR4 PC4-27200C16 3400MHz Quad Channel Kit - White (GLW416GB3400C16AQC) @ £259.99 inc VAT
Specification:-
- Tested Speed: DDR4-3400 MHz (PC4-27200)
- Tested Latency: 16-18-18-36
- SPD Voltage: 1.2V
*Only approved on Gigabyte X99 SOC Champion and MSI X99S XPOWER AC.
Only £259.99 inc VAT.
ORDER NOW
GeIL Super Luce 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - Red (GLR416GB3000C16QC) @ £215.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
GeIL Super Luce 16GB (4x4GB) DDR4 PC4-27200C16 3400MHz Quad Channel Kit - Red (GLR416GB3400C16AQC) @ £259.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
GeIL Super Luce 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - Blue (GLB416GB3000C16QC) @ £215.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
GeIL Super Luce 16GB (4x4GB) DDR4 PC4-27200C16 3400MHz Quad Channel Kit - Blue (GLB416GB3400C16AQC) @ £259.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
Do the LEDs wave from side to side or just idle?
From looking around they "breath" so fade in and out, this also varies depending on temperatures.
Level 1 –> 40c or less: 13 beats/min
Level 2 –> 40-45c: 60 beats/min
Level 3 –> 45-50c: 80 beats/min
Level 4 –> 50-55c: 120 beats/min
Level 5 –> >55c: 200 beats/min
That's not fair. If only you had released these a few weeks a go!. The white ones would be perfect for my build!
IF thats the case why not have them in the colours the boards are in????
true that orange yellow and white would have been the better colours. red would go with asus and blue would go with asrock. these make no sense :confused:
has anyone tested these and are they any good ? Not wanting to OC them ,only run them at stock.
Sure there is better memory out there if you want to OC, but I am not, just after good fast DDR4
Looking at 32GB of the 3000Mhz to go on an Asus X99-S board.
When I saw the product title all I could think of was "Super Loose"... my imagination has start furnishing my brain with quite a few images that I will now take to my grave :(
