- 28 Jan 2005
- Southport
Hi all,
The clutch fluid in my civic is gone a nice green / black colour and is overdue being replaced. From what I have read this should be a fairly simple job:
-Take most of the old fluid out of the reservoir.
-Top up with new DOT 4 fluid and keep it topped up throughout.
-Clutch down
-Open bleeder
-Close bleeder
-Pull up peddle (no pressure to spring back itself)
-2 pumps of clutch and then hold down again
-Open bleeder.....
And repeat until new fluid is coming out the bleeder. Anything ive missed, handy tips or do's and dont's? I will use a 2nd person to do the clutch work while I open and close the bleeder.
One other thing im worried about is the cap off the bleeder on the slave cylinder is missed and the thread has a bit of rust on it. I will use some penetrating fluid before trying to open it but has anyone had any problems with them shearing off?
Thanks
-Clutch down
-Open bleeder
-Close bleeder
-Open bleeder.....
Thanks
