Some help with Oracle, simple script i can't get to behave
18 Oct 2002
Having difficultly removing the newest records from a table. I've probably gone about it the wrong way in the first instance but I've made it this far :) I've created a temporary table, inserted the records (entityid, addressid and startdate of the address) and then just want to remove the newest record for each EntID.
What i want to do is pick out the AddressID's with the newest date and remove them, but i'm getting an error because the addID is not in the select statement:
Error report -
SQL Error: ORA-00932: inconsistent datatypes: expected NUMBER got DATE
00932. 00000 - "inconsistent datatypes: expected %s got %s"
*Cause:
*Action:
Code:
CREATE TABLE ENTADD(EntID number(10), AddID number(10), StDate date);
Insert BLAH BLAH
DELETE FROM ENTADD
WHERE AddID in
	(SELECT MAX(StDate)
	FROM ENTADD
	GROUP BY EntID);
any ideas?
B@
Try putting the AddID in the sub query or else how it is going to match it with the "AddID in" as AddID isn't returned.
i had tried that, get this error instead:
DELETE FROM ENTADD
WHERE AddID in
(SELECT MAX(StDate), AddID
FROM ENTADD
GROUP BY EntID);
Error report -
SQL Error: ORA-00913: too many values
00913. 00000 - "too many values"
*Cause:
*Action:
B@
You'll need to add it in the group by statement as well, as it is not a calculation.
Is it not because your sub query is returning a date and your are trying to match that to the numeric AddID?
I would have thought you want this:
Code:
DELETE FROM ENTADD
WHERE StDate in
	(SELECT MAX(StDate)
	FROM ENTADD
	GROUP BY EntID);
If i group by date or addressID then it won't pick the highest date grouped by entityID so it won't work will it?
An entityID has multiple addressID's, each with a startdate. I need the newest address ID per entityID deleted.
Code:
DELETE FROM ENTADD
WHERE StDate in
	(SELECT MAX(StDate)
	FROM ENTADD
	GROUP BY EntID);
That'll just delete any entries with those dates though. The unique identifier is either a combination of entityid AND date or just addressid
B@
DROP TABLE ENTADD;
Insert INTO ENTADD (EntID, ADDID, stdate) VALUES (1,2, sysdate+1);
Insert INTO ENTADD (EntID, ADDID, stdate) VALUES (2,2, sysdate+2);
Insert INTO ENTADD (EntID, ADDID, stdate) VALUES (3,2, sysdate+3);
Insert INTO ENTADD (EntID, ADDID, stdate) VALUES (4,2, sysdate+4);
Insert INTO ENTADD (EntID, ADDID, stdate) VALUES (5,3, sysdate);
Insert INTO ENTADD (EntID, ADDID, stdate) VALUES (5,2, sysdate+5);
DELETE FROM ENTADD
WHERE rowid = (
SELECT rowid
FROM entadd a
WHERE a.addid = '2'
AND a.stdate = (
SELECT MAX(stdate)
FROM
entadd
WHERE addid = a.addid)
...The unique identifier is either a combination of entityid AND date or just addressid
B@
Yeah, had spotted that after I posted it. Try this:
Code:
DELETE FROM ENTADD A
WHERE A.StDate in (SELECT MAX(B.StDate)
                         FROM ENTADD B
                         WHERE A.EntID = B.EntID
                         GROUP BY B.EntID);
DROP TABLE ENTADD;
DELETE FROM ENTADD
WHERE rowid = (
SELECT rowid
FROM entadd a
WHERE a.addid = '2'
AND a.stdate = (
SELECT MAX(stdate)
FROM
entadd
Will try that out
Code:
                         FROM ENTADD B
                         GROUP BY B.EntID);
that'll still delete anything which matches that startdate, irrespective of what entityID it is, because you're just deleting anything with that startdate.
B@
DROP TABLE ENTADD;
DELETE FROM ENTADD
WHERE rowid = (
SELECT rowid
FROM entadd a
WHERE a.addid = '2'
AND a.stdate = (
SELECT MAX(stdate)
FROM
entadd
that's not going to remove the newest address from each entityID i dont think
B@
DELETE FROM ENTADD
WHERE rowid = (
SELECT rowid
FROM entadd a
WHERE a.EntID= '2'
AND a.stdate = (
SELECT MAX(stdate)
FROM
entadd
WHERE EntID = a.EntID)
0 rows deleted, what've i done wrong?
B@
Did you run the insert, looks fine on my phone :)
Failing that mail me on trust and I'll do it when I get home :)
definitely data in the table:
thanks for your help!
B@
hi,
Try
DELETE FROM ENTADD
WHERE rowid = (
SELECT rowid
FROM entadd a
WHERE a.EntID= '268545'
AND a.stdate = (
SELECT MAX(stdate)
FROM
entadd
Then do
Select * FROM entadd a
WHERE a.EntID= '268545';
You should only see the entry with the date of 01-Jan-01, is this what your trying to do for the full table?
yep, that's worked on that record :) so i tried the below and got another error:
DELETE FROM ENTADD
WHERE rowid = (
SELECT rowid
FROM entadd a
WHERE a.EntID = EntID
AND a.stdate = (
SELECT MAX(stdate)
FROM
entadd
Error report -
SQL Error: ORA-01427: single-row subquery returns more than one row
01427. 00000 - "single-row subquery returns more than one row"
*Cause:
*Action:
B@
DELETE FROM entadd a
WHERE EntID IN
SELECT entid
FROM entadd
GROUP BY entid
HAVING COUNT(*) > 1
AND a.stdate = (
SELECT MAX(stdate)
FROM
entadd
Heh, took me a while to understand you're problem, email on trust if you get stuck I'll try get back to you
