I tested tested the loop out
with 1 d5 vario max speed and once pressure or loops if filled up circulation stops dead.
tried removing the external 420mm rad and same issue.
tried using 2 pumps one at the start of the loop and one mid loop to try and get some circulation again as soon as the loop is full flow stops dead.
am i doing something wrong here or what cause the only other thing i can think of is that there is a high flow blockage somewhere. or high resistance.
if i try to blow out all the water i have to put a lot of effort into draining the system as in a lot of pressure
i really have no idea what to do next.....
is there a pump out there from some other vendor that has very very high head pressure.
cause i think thats what i need to get the flow going.
