Time lapse photography cam ?
20 Oct 2006
London
Hi guys,
I am after a dslr camera to shoot landscape and solar photography. This will be my first dslr cam I will purchase.
Looking for a budget value for money cam around £300.
is there a cam with built in timer shutter speed as apposed to buying a digital timer remote.
thanks
My advice would be focus on getting your camera and not worry about this as feature as an intervalometer can be had for around £13. I'm not aware of Canon DSLRs with this feature inbuilt. Not sure the Nikons do either.
Higher end Nikon DSLRs have a built in intervalometer.
Since you are on such a tight budget I would be looking at second hand m43 gear.
thank you all. much needed.
using lapse it pro on my phone was becoming somewhat a joke
Canon's own software bundled with DSLRs allows you take a time-lapse by hooking up a laptop to it with a USB cable.
I used to do it as far back as when the 350D launched.
thanks for the info. i will just buy a timer remote, rather than carrying a laptop around
Hi again.
so i have been doing a bit of searching and i think the m43 camera as definitely my sort of thing.
I came across the OLYMPUS OM-D E-M10 which is at currys for £499.
any input regarding this camera and its specs. is there something better for same price or cheaper but value of money.
many thanks again
