[TW]Fox;27991725 said:You can of course take it to court if you wish. If you were wrong, you will be ordered to pay. If you were not, you will not.
The idea behind fixed penalty notices is to save both you and the council the bother of court. In return for this you pay a lower penalty.
If you were guilty of whatever the council issued FPN is for there is nothing to be gained from not paying, exercising your right to take it to court will just cost you more time, money and hassle. If you were not guilty, then raise a dispute in the way it explains you can.
This basically.
If you didn't do whatever you got the ticket for, you should have appealed it through the proper channels.
If you did then all you've done by refusing to pay is buy* yourself some additional time before payment.
I use the word buy* because if this does go to court and you are found liable then you will have to pay the original fine, plus collection & court costs which will be significantly higher than the original amount (as you can see by the fact that it is now up to £400), not to mention the inconvenience to you.
Of course you can decide to ignore any court orders as well, which means if a judgement is made against you then bailiffs can come to take to your stuff - they're most likely to take your car, which, on the plus side means you wont have to worry about any more parking tickets
