- 12 Nov 2014
- Westgate On Sea, Kent
i been trying the default overclocking available on this processor i5-4690K and motherboard the gigabyte Z97x-SLI.
i set it to 60% and got 4.5ghz and was stable but i found under a prime95 torture test that the temperature kept increasing.
it got very hot at 97 degrees Celsius .
now from running old system i find that very hot. what is the best temperature range for these new processors. it runs from 25 to 35 at stock with just normal stock speed 3.5 to 3.9 turbo range.
i have never tried overclocking the i5 before as this is my first time using a new processor. last time i overclocked was on the old lga775.
is there a good guide to overclocking this particular model and the gigabyte motherboard. as said it was stable but go very hot. the cooler used is the following.
Raijintek EreBoss High performance CPU Cooler UI=6588599
this test overclocking was done using preset bios settings.
