Recommended power supply for 980 ?
Hi and welcome.
Your link doesn't work but I am guessing it is a Gigabyte G1 card?
Can you list everything in your system? and if you wanted the option of SLI (if its supported by your board).
Yeah, but that doesn't tell me what CPU, drives, fans, cooling you have, it all adds up in wattage terms.
Hi and welcome.
Yeah its a 980 sorry about the link. My system will be as follows
- Case: NZXT h440
- CPU: i7 4790k
- Motherboard: Gigabyte Z97X-Gaming 5
- RAM: CORSAIR VENGEANCE 1600mhz i think
- Graphics:Gigabyte NVIDIA GTX 980 4GB DDR5 PCI
- Primary Drive: WD 1TB 3.5 inch Internal Hard Drive - Caviar Blue
- Power Supply: xfx 550w currently need to replace
Thanks so much for the help in advance :)
sorry about the previous post missclicked :(
Yeah it will work on that PSU and XFX PSUs are usually made by Seasonic so its not a nasty item.
I would have only suggested this PSU anyway - https://www.overclockers.co.uk/showproduct.php?prodid=CA-024-EA - Fully modular, Gold rated, made by Seasonic, Eco fan mode so turns off at low load/temperatures.
SLI would be a 850W PSU and this one - https://www.overclockers.co.uk/showproduct.php?prodid=CA-017-EA - is in budget and made by Superflower.
Thanks for the help i appreciate it :). Is there any 750w power supplys you recommend too.
