Corsair RM750 + E-ATX MOBO?
22 Feb 2010
Cleckheaton
Hi everyone,
I currently have a Corsair RM750 PSU and was looking into moving to an X99 rig with an E-ATX motherboard.
I know E-ATX boards need an extra cable from the PSU, but this Corsair one only comes with 1 x 4+4 pin CPU cable.
So, could I use an 6+2 pin PCI-E cable as they plug into the same sockets on the PSU? Or do I need to invest in a new PSU that comes with 2 x 4+4 pin cables?
EATX boards don't *need* the extra cable, it's just there as an option should you be using it in a way that requires more power than one cable can supply.
Ah right OK, I didn't realise it was an option.
So if I'm going with a 5820k and not going SLI, would you say I wouldn't need the extra power?
Thats right what he said, many boards just work spot on with a single 8pin ATX connected, maybe dual CPU boards do need two of them (one per CPU), but I have run a few single cpu boards with just the main 24pin+8pin and left additional 4pin/8pin ATX empty and never been held back.
P.S the pins of the PCi-E maybe the same at the PSU end, but at the end that plugs into a gfx card they will be a different shape than a 8pin ATX to stop you making a costly mistake.
Ah right OK, good stuff. Saves me an extra upgrade for now :D
Time for the money planning stage :P
Cheers for your help fellas :)
