I'm going to build a new dedicated gaming rig from the ground up in 3 or so month's time. Main thing I'm umming and ahhhing over is to wait for Skylake, or go X99 hex core (I really like the idea of 6 physical cores over 4, as I think some games will start to benefit).
I'm posting this in the GPU section, as I have concerns about running 2 cards in SLI at differing PCIe speeds. Bear with me....
From my limited research, if I do go x99 I would most likely get a 5820k chip. This 'only' allows 28 PCIe 'lanes', so if you run 2 cards in SLI, one will be at x16 and the other at x8. This is as I understand it, is that right?
Now, I'm no expert, but I'm something of an obsessive about using SLI and experiencing and eliminating stutter and microstutter in certain games. I've used SLI for years, currently on 780Ti SLI. I want to go one TX probably to start with, but have itchings to try out 4k soon, so will end up needing 2 cards. It will happen
It may be daft, but I can just sense problems arising from running 2 cards in SLI at different PCIe speeds. So my questions are:
1. Does anyone run this 5820k x99 set up now with SLI and have any input?
2. Are there any motherboards that allow you to force x8 for both cards, rather than one at x16 and one at x8? From what I've read x8 with "PCIe 3" is more than good enough anyway.
3. Should I just fork out for a 5930k with the full 40 lanes so there are no issues and both cards will run at x16
4. Should I wait for and get Skylake instead?
Ta
Ta
