I really like the HE400i. I thought it was a good cheaper alternative to the HE500/LCD2 with good bass and mids and good energy at £360. They don't quite have that high end resolution but they are in-between the HD650 and HE500.
The K712 is excellent and easily end game on a budget. The only issue I had was the upper mids which someone else could easily live with.
Thanks for the comparison with my current can's.
Yes, I did mean the K812
You've turned my head towards the Hifiman HE400i, reading around echo's what you say & not many negative reviews...
I know its not about looks but the older Hifiman's always look very cheap or old looking if you know what I mean, take the older 400's as they looked like they were from the 70's, the build of them never enthralled me but they have stepped up with the 400i...
Just see this review below & they show some cloth/velour on the pad with leather/leatherette on side, first time I've seen this - I like it ! Must help with the sound ?
I don't get on with none breathable materials, that's why I sold my HP200's. Hot ears & sticky head with my skinhead lol...
http://www.techpowerup.com/reviews/HiFiMAN/HE-400i/
Haha Nah I'm done. To be honest when I got into audio I didn't want to come this far. There isn't anything else I want in a headphone.
[ui]ICEMAN;27736238 said:Did you get to try the different pads on the PM-1's? I've found the new alternative lambskin pads to brighten the headphones significantly. They're insanely easy to drive but I do think they sound best on their own amp.
I do prefer the wider soundstage I get from the HD-800's and there's definitely more detail in the HD's than the PM-1's but they're probably not as easy to listen to IMO.
[ui]ICEMAN;27746981 said:They're a little pricey in the UK I agree. Over here they're $1100, about $400 less than the 800's or T1's.
For mixing and audio analysis, I didn't want phones that flattered.
Sounds like Audeze finally screwed up - so I expect you'll be moving them on and getting the PM3 then?
