- 20 Apr 2011
- Stoke on Trent
Hello All
Well, i have sold my soul and bought an old Dell T5500 with 2 x Xeon E5620's (the price was right!).
I plan to upgrade it a little before i start to use it, but would like opinions/advice off the people here, so i dont do anything silly (other than buying the old Dell PC...).
This PC is not for gaming. it is for software development, i will run a few virtual machines on it too (not permanently). Photoshop, triple monitor multitasking and general PC use (word, emails, YouTube, the odd HD video and general stuff...)
Hopefully i will not be pushing this PC to the max, but my faithful little dual core work PC has been working its knackers of now for too long.... and is due a good retirement, probably as a backup device.
Any advice is much appreciated!
- The PC is coming with an old Quadro card. I would like to ADD my (oldish) HD6950/70 to it, so I can have 3 monitors (independent), but i don't think the DELL PSU comes with the correct connections for the 6950.
I have a goodish Antec 620watt PSU. should/could i put this into the DELL? Does it have the power for dual Xeon's? + 2 x (oldish) GPU's
I assume I can run 2 different colour GPUs. I have managed to do this in the past (am at present, have an AMD and Nvidia in the same PC and all works OK, with a little extra config). - The DELL comes with 8GM ram (in 2gb + 1gb +1gb, for each CPU). I think the Xeon E5620 are tri channel. I would like to upgrade the ram to 3x2gb and 6x2gb (for the 2 x CPUs). Can I add any DDR3 to this or does it HAVE to be ECC ram?
- Hard Drives:
I have a few 1TB hard drives, so was going to install 2 of these, and am also thinking of buying a 250gb Samsung as the primary drive mainly to install win7 on (https://www.overclockers.co.uk/showproduct.php?prodid=HD-191-SA&groupid=1657&catid=2101&subcat=2393).
Am also wondering if i should buy a hybrid drive (https://www.overclockers.co.uk/showproduct.php?prodid=HD-292-SE&groupid=1657&catid=1660&subcat=1893) to replace one of the 1TB drives. This drive would be used to install most of my programs to (Photoshop, office, dev software, etc.). Would i see any benefits to this?
(the other 1TB drive if mainly for file storage).
I don't plan to run any RAID. - At some other point I will also upgrade the CPU's to hex core, but will wait until I see a bargain (do the CPU's have to be "matched" or could i run a quad and hex core CPU together?)
- anything else I should be thinking of or buying as an upgrade for the Dell (ideally from OCuk!)?
(also didn't mention the GPU, but there was one in the photos, so this will be a surprise, maybe good maybe bad...)
