Hi guys
Do you think the Asus ROG SWIFT PG278Q will run games on 2x GTX 680 SLI ?
Thank you for your help
. I have Corsair 850 W power supply, do you think it will handle?2x GTX 680 SLI will handle 2560 x 1440 fine but you will need to lower some settings to achieve 144 Hz in some games.
You wouldn't have to lower any setting to achieve 144Hz - 144 fps however is a different story![]()
So the graphics card would need to output at least 144 fps to match the screen's native refresh rate?Isn't 144 Hz (cycles per second) the same as 144 frames per second?So the graphics card would need to output at least 144 fps to match the screen's native refresh rate?
Thank you
Also, what is the colour quality on the Asus rog swith? Do you know any good calibration settings for this monitor? Do you think that the new Acer 27 IPS G-sync will be better? Thank you again for your help.
So with graphic card are you recommend ?
Does the Asus Rog swift have that bad colors? Is it better then another TN G-Sync monitors?
Some games use more vram, you will just need to turn a few settings down. Most will be fine though for the short term anyway. Vram issue is blown way OTT.
And it also the best gaming monitor available...Its the best tn panel available
