** Inno3D - 3D Printers & Filament - IN STOCK NOW **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We now have two models of 3D Printers in stock now from Inno3D
These printers are really accurate and offer excellent value for money.
we stock the full range of inno3D and Voltivo filaments also.
SHOP FOR 3D PRINTERS HERE
Inno3D Printer D1, Open 3D Printer @ £869.99 inc VAT
The Inno3D Printer D1, Open 3D Printer is an open bed unit capable of printing advanced models quickly and efficiently. The D1 3D Printer is a rugged design featuring a metal chassis with a completely open build area. This machine is a very high end item designed to be hard wearing and last for years to come.
The D1 is the Industrial build quality unit designed for easy access with a colour touch screen LCD Display enabling you to print files within a few easy clicks. In addition to this the D1 has an SD Card slot which allows for easy changing of print files.
The D1 is easily calibrated using the in built platform which removes the requirement for thickness measurements. The print platform is made from hard wearing and durable Aluminium with temperature control to enhance the stability of your model.
The Inno3D Printer includes ultra fine layer resolution up to 0.1mm of intricacy for high precision printing.
the modular nozzle design means that changing the nossle of the printer is a quick task with plug and print function.
Features:
- Auto Braces Creation Technology (BCT)
- Print floating 3D objective with ease
- Auto Raft insertion
- Conveniently peel off the 3D Object from bed
- Auto bed level calibration
Specification:
- Printing Technology: Fused Filament Fabrication
- Print Nozzles: Single Nozzle (0.4mm)
- Build Volume: 140mm (L) x 140mm(W) x 150mm (H)
- User Interface: Touch Screen LCD display
- Layer Resolution: 0.13mm - 0.3mm
- 3D Object Supports: Fully Automated, Easy to peel off
- Filament: 1.75mm PLA
- Filament Color Choices: Multiple colors PLA
Software Support:
- Free 3D Printer control software with STL to printer file format conversion
- Work with any 3D applications which can export STL file format
System Requirements & Connectivity:
- Processor: Intel® or AMD® with dual-core processor or above
- System Memory: (Windows 98 / XP) -4GB . (Windows 7 / 8) -8GB
- Screen Resolution: 1024x768
- Disk Space: At least 20GB free space for printer application
- OS Support: Microsoft® Windows® XP / 7 or Windows® 8 (32 bit / 64 bit)
- USB 2.0 port for Workstation connectivity - with USB device driver
- SD-Card interface for direct file printing - support up to 32GB SD-Card
Weight and Dimentions:
- Print unit weight (without cartridge): 10kg
- Print unit dimension: 39cm (length) x 36cm (depth) x 54cm (height - include the filament guide tube)
- Gross Weight: 14.5kg
- Carton dimension: 47cm (length) x 44cm (width) x 49cm (height)
Only £869.99 inc VAT.
ORDER NOW
Inno3D Ducker M1 Closed 3D Printer @ £1,089.95 inc VAT
The Inno3D Printer M1, Closed 3D Printer is an Closed bed unit capable of printing advanced models quickly and efficiently. The M1 3D Printer is a rugged design featuring a metal chassis with a completely open build area. This machine is a very high end item designed to be hard wearing and last for years to come.
The Inno3D Printer M1, Closed 3D Printer is fully enclosed with stable airflow channels to ensure optimum temperature control on your projects. This gives you the very highest print quality.
The M1 is the Industrial build quality unit designed for easy access with a colour touch screen LCD Display enabling you to print files within a few easy clicks. In addition to this the M1 has an SD Card slot which allows for easy changing of print files.
The M1 is easily calibrated using the in built platform which removes the requirement for thickness measurements. The print platform is made from hard wearing and durable Aluminium with temperature control to enhance the stability of your model.
Features:
Specification:
- Filament: 1.75mm PLA & ABS
- Filament Color Choices: Multiple colors PLA & ABS
Software Support:
- Print unit weight (without cartridge): 11kg
- Print unit dimension: 49cm (width) x 43cm (depth) x 52cm (height)
- Gross Weight: 16.5kg
- Carton Dimension: 56cm (length) x 52cm (width) x 60cm (height)
Only £1,089.95 inc VAT.
ORDER NOW
it could print you a girlfriend.
i dont know if she would be much of a talker.
and depending on how good you are at 3d print modelling, would impact how much of a looker she was.
give it a go and report back :)
Kelly LeBrock now looks like the women who ate Kelly LeBrock from Weird Science..."Should we give her a brain..."
