** DUCKY LEGEND - £30 PRICE DROP UNTIL MONTH END **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Big savings on the best looking board Ducky make right now!
be a legend and spend the money saved on a cheeky nandos.
sound anyway.
Ducky Legend Blue LED Blue Cherry MX Switch Silver Aluminium Case - UK Layout @ £99.95 inc VAT
Ducky DKLE1408S Legend Mechanical Keyboard
Ducky Legend uses 5mm thick aluminum case top design for the most solid keyboard in the industry. The bead blast finished aluminum top is has a modern industrial look that is suitable on your desk for work or gaming. Ducky Legend is powered by an ARM architecture micro-controller and uses the most reliable Cherry switches. Even the PCB is dual layer construction to ensure the keyboard will work for years on end. The backlighting effects feature our most popular Reactive Mode, as well as User Customizable Zone backlighting, and our newest Explosion Mode. These backlighting effects give you a great keyboard to look at in addition to being a keyboard you can rely on.
Features:
- 5mm Thick Aluminum Case Top: Ducky spared no expense to bring you 5mm thick upper case. This adds to the legendary solidity Ducky is known for. This is not just the Ducky's thickest aluminum case top, but the thickest in any mass production keyboard.
- Satin feel bead-blasted finish: The aluminum case top has a smooth satin like bead blasted finish. This gives the keyboard a more mature understated look compared to a brushed aluminum. The case top is anodized to protect the finish as well as enhance durability to the everyday wear and stains.
- Cherry MX Mechanical Switches: Ducky uses only genuine Cherry switches. The keyboard is available in different switches to suit different preferences.
- Durable dual layer PCB design: Dual layer PCB is more durable and reliable than single sided PCB. This will give longer life expectancy as well as signal stability of the keyboard functions.
- Powered by ARM M3 MCU - Ducky Shine 4 is powered by an ARM M3 micro-controller. This powerful controller allows advanced functions as well as stunning backlighting effects.
- USB N-Key Rollover - Under USB, the Ducky Shine 4 can handle any number of simultaneous key presses. You can use the keyboard confidently in any situations knowing that there will never be ghosting or key blocking issue.
- 1000HZ Report Rate: The keyboard sends update of the keyboard's status to the computer every 1 millisecond. This minimize the time from when the key is actuated and the computer receiving the signal, giving you a lag free performance
- Windows key lock function: To prevent accidental key press interrupting your gaming session, the Windows key can be easily disabled with 2 key presses. Don't let stray key presses ruin your day again.
- USB Repeat Acceleration: Ducky brings adjustable repeat rate and repeat delay to USB keyboards. You can fine tune the repeat rate and repeat delay for gaming or your specific applications.
- Anti-Ghosting key matrix: Legend can accept any key combinations without ghosting or key blocking. In addition, the keyboard can be switched to full USB N-Key Rollover mode that accept as many simultaneous inputs as you want.
Backlighting Effects:
- 100% Full Backlight Mode: All the individual keys are backlit. This mode allows you to change the backlight's color and brightness to your preference.
- Breathing Mode - Keyboard's backlight rhythmically fade in and out creating a calm and tranquil backlighting effect.
- Explosion Mode : With every key press, a burst of light rushes out from the point of origin akin to an explosion.
- Reactive Mode: Ducky's innovative backlighting effect. Individual key lights up with every single key press.
- LED Zone Customization Mode - This mode provides 2 sets of user customizable memory for storing whichever key you want to light up and the color of the backlight. These zones are independent of other backlight modes and can be used concurrently.
Specification:
- Model: DKLE1408S
- Type: Mechanical Keyboard
- Switch Cherry MX Mechanical Switch’s
- Interface: USB 2.0
- LED Colour: Full Colour LEDs
- Keycaps material: ABS
- Legend printing: Lasered
- Dimension 458(L) x 155(W) x 36.5 (H) mm
- Weight:1470g
Was £129.95 Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Ducky Legend White LED Blue Cherry MX Switch Black Aluminium Case - UK Layout @ £99.95 inc VAT
Features:
Specification:
- Model: DKLE1408S
- Weight:1470g
ORDER NOW
Ducky Legend Mechanical Keyboard, Blue LED, Red Cherry MX Switch Silver Aluminium Top - UK Layout @ £99.95 inc VAT
Features:
Ducky Legend can accept any key combinations without ghosting or key blocking. In addition, the keyboard can be switched to full USB N-Key Rollover mode that accept as many simultaneous inputs as you want.
1000Hz report rate:
The keyboard sends update of the keyboard's status to the computer every 1 millisecond. This minimize the time from when the key is actuated and the computer receiving the signal, giving you a lag free performance.
Note: USB Acceleration may work differently in different applications. Please use a suitable setting accordingly.
Specification:
Dimensions: 458 x 36.5 x 155 mm (W x H x D)
Weight: 1.47 kg
Color: Silver
Keys: Cherry MX Red (mechanical)
Release pressure: 45g
Release Height: 2 mm (4 mm to the ground)
Layout: UK ISO
LED lighting: Blue
LED modes: 100%, 0%, Breathing, LED Zone Customization, Reactive, explosion)
Connectivity: USB 2.0
USB polling rate: 1.000 Hz (adjustable)
Compatibility: Windows XP, Vista, 7, 8
Scope of delivery:
Grey WASD keys
Keycap pliers
ORDER NOW
Ducky Legend Mechanical Keyboard White LED Red Cherry MX Switch Black Aluminium Top - UK Layout @ £99.95 inc VAT
Features:
1000Hz report rate:
Specification:
Weight: 1.47 kg
Color: Black
Layout: UK ISO
LED lighting: White
Scope of delivery:
Grey WASD keys
Keycap pliers
ORDER NOW
This so makes me want to sell my corsair mech board. What are the freebies mentioned on the product page?
