GTX 970 - No Display
11 Apr 2014
Hi,
I've just bought a MSI GTX 970.
The card powers up and the fans work, as well as the MSI LED. Issue I have is that if I plug a DVI or HDMI in to the graphics card I get no display, but the built in mobo graphics works.
Any reason for this? Struggling to solve and use my new gfx :(
Cables are fine, PSU is and motherboard is fine. If I plug in my old AMD R9 270x with the same cables it works without issue. bios is set to ise PCI express as first device.
My specs are
MSI GTX 970
Intel I5 2500
gigabyte h67n mobo
I am thinking I probably need to upgrade my mobo....and CPU ?
Having researched online this seems to be a common issue where updating the bios fixes it for most people. I've updated my bios to latest using the above link and unfortunately no joy.
I can test the card in a different machine on Monday to check the card is fine, but I really think it is fine, especially after reading all the posts online with the same issue as me.
Any more suggestions to try before I cry and spend more money?
Errr, I seen people flash Z77-D3H boards with BIOSes from last year and certainly earlier than the 9 series cards and it has worked for them.
Upgraded BIOS to version 10. Still no luck :( No display using DVI or HDMI.
Managed to test it on another machine as well and it worked fine, so it has to be my motherboard.
Am I all out of luck and going to need to purchase a new mobo?
If yes.. any recommondations for a m-atx board? Was thinking ASUS ?
Before buying any new hardware, go into the BIOS 'advanced features' and make sure that "init display first" is set to [PCIE x16] and "Onboard VGA" is set to [Enable if no Ext PEG]
Depends on what you can find, they will be 2nd hand now.
Try and get something on a Z77 chipset as that was the latest for that time.
