- 31 May 2009
It irritates the **** out of me when people use the dollar sign.
Especially the chap who paid for an unlicensed licence
About this so called free upgrade. I take it the upgrade we get will only be valid on the computer we use it on and if we move over
to a completely new computer, the upgrade we got will be useless and so we will need to buy a Windows 10 license to use it on
our new computer since the upgrade we got and the installation is only for that device we used it on?
Any idea what would happen if we upgraded for free but decided we didn't like it and wanted to revert back to 8.1?
FYI... the two versions you mentioned are the same
Pre-intalled = OEM
You mean OEM vs Retail.
OEM is *supposedly* tied to the motherboard (although you can still re-license if you have had a failure and replace the motherboard etc or simply use the phone system and tell them it's only installed on one PC)
Retail is the one you can officially take with you.
i think i read somewhere saying no you wouldn't be able to revert back the license
I take it if you actually bought Windows 10, then you can use it on as many computers as you like
obviously as long as the previous computer you were using it on has been deactivated?
Or do we now need to purchase a license every time we move to a new computer?
I think ultimately Microsoft are aiming to wean us all to the cloud, no more OS installed localy, everything done remotely through the internet, including your files and documents storage.
