- 6 May 2015
Dear friends,
I had some screen freezes when a video was playing (Most of the time it is just the video screen that freezes and then I can't do anything anymore. The computer does NOT reboot. I do NOT get a blue screen BSOD). Most of the time, it was a 4K video that was playing from my SSD Boot disk. While playing a 4K video, the CPU uses below 40% and most of the time, the GPU is barely used except some very short peak moments of more than 90% (but this is only very short).
The system I used was as follows (it is a NEW system):
A) Motherboard: ASRock 970Pro3 R2.0
http://www.asrock.com/mb/AMD/970 Pro3 R2.0/
The latest version of the BIOS is installed (version 1.80)
I installed the drivers from the installation CD
B) AMD FX8300 processor (8 core)
http://products.amd.com/en-us/DesktopCPUDetail.aspx?id=...
C) Special Cooler used for the processor: a top down cooler
On the website of the motherboard manufacturer (Asrock, it was recommended to use this kind of cooler when using the AMD FX8300 processor)
ZALMAN CNPS10X OPTIMA
http://www.overclockers.com/zalman-cnps10x-optima-cpu-c...
D) Gigabyte Radeon R7 260X OC 2 Gb graphics card
http://www.gigabyte.com/products/product-page.aspx?pid=...
I installed the latest drivers from the AMD website
E) 600 Watt power supply
F) 250 GB SSD (Samsung EVO 850)
G) Windows 7
I read on some website that other people too had freezes or blue screen (BSOD) with this motherboard. Do you think that the motherboard is a badly designed model and that I should get another motherboard (a different type/model)? Please answer a simple YES or NO and Why.
Thank you.
G) Windows 7
Thank you.
