Are you sure?Nothing to worry about.
Hi!
Im just wondering will AMD FX 9590 Bottleneck 2x 290x in crossfire 1080p ?
I know that FX 8320 4,5Ghz does bottleneck 2x 780s 1080p
To some degree, yes. Best to post your heaven, 3dmark firestrike scores and a few game benchmark scores once you get your new cards. Then we can compare with someone using the same cards but with an Intel CPU etc.
Eitherway, best to test it first with your current CPU. Maybe you'll be perfectly satisfied with it's performance, even if it is bottlenecked a little.
No see now that's exactly what you don't want to do. Of course there's going to be some one out there with a faster rig than yours but yours will be more than good enough.
If it didn't bottleneck, we'd all be running AMD CPU's since they'd be "good enough" but they're not meant for this type of set up.
Synthetics like Firestrike are poor indicators.
And you'll bottleneck at 1080p. Maybe not in every game on the planet (Since there's like.. Thousands) but you'll certainly bottleneck a lot. There's differences in FPS figures with 1 290X and an FX95 versus an i5/i7. Two 290X's will be an obvious bottleneck.
Hi!
go spend £350 on an i7 setup and be less bottlenecked.
Even if it is bottlenecked in less intensive games, does it really matter if the difference is between having a minimum fps of 60 vs 100?
In the gpu intensive games where you've put the settings/resolution up so that you are running at below 60fps, I doubt the bottleneck will be much.
As humbug put it, do you really want to spend £350 for little to no visual benefit?
