- 25 Nov 2011
- The KOP
Guys is it possible to use heatsinks on VRM and still be able to remove them should I wish to re-install stock cooler?
are you talking motherboard or graphics cards? Do you mean adding a waterblock to the vrms? what board / card?
more info needed
As long as you use thermal tape such as the Akasa stuff you can easily remove them later. If you use thermal adhesive which is basically glue it's on for keeps.
If ur using the g10 kraken upgrade the 92mm fan as well. The stock one is rubbish.
I went for a silverstone and its dropped my temps loads.
You ever used Akasa Thermal tape?
Thanks I was also thinking this, Noctua 92mm I might use. Do you have anything on the VRM2?
Yeh some copper heatsinks temps occasionly hit the 90's still though
How did you apply yours?
Heat sinks came with thermal tape
It's all I ever use. Stuff that comes with the heatsinks can be hit or miss as to whether they will stay stuck so I have used Akasa AK-TT12-80 Thermal Adhesive Tape instead and have never had a heatsink fall off. You pick pick it up for around £4 although OCUK no longer sells it. Before applying the heatsinks take the time to clean the chips with IPA to remove any oily residue left over from the stock cooler and things will stick better.
Ain't a full block a better way ? I take it the kraken is a AIO![]()
