I'm leaning more towards a cheap P38 until I decide if I want to move the F11 on for a 4.4 TDV8, or keep it and save for a 3.6 TDV8...
Why not do this, ditch the F11 and go straight for a nice L322?
In fact, no, I'll just do it to make the point.
I'd have to up my budget to L322 money anyway to get a decent Hilux or Landcruiser anyway, which would be about the only Jap 4x4's I'd likely consider, but they look like this...
Hilux:
Landcruiser :
Compared to a Range Rover that looks like this :
But even the P38 has a nicer interior than the Jap stuff :
Yep. Love motors. Asking about £2k motors, get links for £5k motor...
Then went on to doubling the budget for an early L32
Why not do this, ditch the F11 and go straight for a nice L322?These cheap stop gap cars sound rubbish, just get a nice 4x4 and be done with it.
Make up your mind man
[TW]Fox;28053804 said:Problem is that once you've had something modern like his 2013 F11 you won't want to step back in time a decade and get into an L322. They are great cars but they are not modern cars and show their age. Which is fine at lower budgets but not coming from a 2013 5 Series, depending on the age of L322 he picks he might even end up in one with the electronics system out of an E39 in it! So he'd need to wait for a current model to be in budget which could take some time.
It depends if he wants a 4x4 specifically though. If he does then an L322 is his best bet as the value of his F11 wont touch an L405.
With the value of the F11 he could get a reasonably good L322, it'll probably be a Jaguar based one (like mine) for that budget rather than a really late model, but they are still pretty good. The electronics are fairly old fashioned compared with an F11 but the fundamentals are all there. They have HFP bluetooth, A2DP bluetooth audio streaming, touch screen navigation (No idea what the resolution is on it, but its high, nothing like the terrible old E46 era stuff), digital TV, Harmon Kardon Logic 7 amps and subs everywhere etc.
Depends what he wants from the car obviously. Nothing is free in this world, if he wants bang up to date infotainment in a car like a Range Rover then he will need much deeper pockets than F11 money![]()
It has recently had new airbags all round
That's a lot of car for 2k!
You mentioned that the insurance company don't like the light bar on the front, how come did they say why? I'm just curious
Looks like a decent purchase, how much do you foresee spending to make it "right"?
