Assetto Corsa and Crossfire (Tri-fire/Trifire)
27 Apr 2012
London
Just bought the game as it is half price on steam.
I'm using 3x AMD 7950 3Gb and 3 monitors (5884x1080 because of bezel compensation)
Driver is: 15.5 Beta
I already created a profile for acs.exe
Post effects are off ingame
if I use default mode it uses 1 card only,
if I use AFR friendly it uses all 3 cards but I have really bad flickering over the car and on the side of the tracks - I get really good fps and high gpu usages,
if I use Optimized 1x1 - I get 5fps and high gpu usages,
if I use BFBC2Game.exe profile - I get 5fps and high gpu usages.
Any suggestions?
Where was it mentioned that 15.5 has an AC profile? Must've missed that one.
The BFBC2 profile works well enough with Hawaii, so not sure why it's so bad with Tahiti...
Try different reflection settings with AFR mode to see if it stops the flickering.
Certain combo's work nicely with other profiles such as High/Low, High/High etc.
I installed the 15.5 and made no difference, I think they were not made for AC, maybe for witcher and project cars.
I will try again today with different settings, lets see.
BFBC2Game.exe profile doesn't work for me, AFR friendly gives me a great fps and gpu usage but the windows, mirrors and side of the tracks are flickering.
Have you tried playing with different reflections settings?
Also try the BF4 or F1 2013 (I think) profile, but you'll probably need to disable onscreen apps (excluding track map and essentials and there may be a couple of others) and it may not scale with three cards.
