Family PC spec
19 May 2015
Hi all,
Would anyone be able to advise me on a build spec for a home Pc? Will be used for office stuff, web browsing etc.
It won't be used for any type of gaming, so graphics not really important. I'd rather concentrate on good general performance.
Budget is 500-600. OS required. Small but pretty would be nice too!
Thanks in advance.
Intel ITX build.
YOUR BASKET
1 x Intel Core i3-4150 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £97.99
1 x Kingston HyperX Fury 240GB 2.5" SATA 6Gbps Solid State Drive (SHFS37A/240G) £85.99
1 x MSI H97I AC Intel H97 (Socket 1150) DDR3 Mini ITX Motherboard £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £61.99
1 x Cooler Master Elite 130 Mini ITX Case - Black £45.95
1 x SuperFlower Golden Green HX 350W "80 Plus Gold" Power Supply - Black £42.95
1 x GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) £39.95
1 x LG 24x DVD±RW SATA ReWriter (Black) - OEM GH24NSC0.AUAA10B £13.99
Total : £562.90 (includes shipping : £11.75 Ex.VAT).
AMD ITX build:
YOUR BASKET
1 x AMD Kaveri 7700K 10 Compute Core APU w/ Radeon R7 Graphics (4 CPU + 6 GPU Compute Cores) - Retail £99.95
1 x Gigabyte F2A88XN-WIFI AMD A88X (Socket FM2+) DDR3 Mini ITX Motherboard £79.99
Total : £564.85 (includes shipping : £11.75 Ex.VAT).
No monitor required, keyboard and mouse only needs to be basic ones.
Both of those options look spot on. Thanks for a nod in the right direction!!
If I wanted to add a graphics card, for 50-60....what would get the thumbs up???
The AMD build negates the need for a separate GPU. Unless you really need one l would look at a GTX 750 Ti, most do not require a separate 6 pin connector and pair it with the i3 build.
https://www.overclockers.co.uk/showproduct.php?prodid=GX-248-MS&groupid=701&catid=1914&subcat=1854
Or you can crossfire the AMD chip with a R7 250 https://www.overclockers.co.uk/showproduct.php?prodid=GX-331-SP&groupid=701&catid=56&subcat=1984
Also if going for the AMD build look to get faster RAM as the APUs benefit from this (as long as the motherboard supports it)
Failing all of that have you seen this as you have access to MM add an SSD + OS and you are golden :)
