Our oven has died and I need to replace it but I've never done anything like this before.
I found out that it slides out pretty easily if you undo a couple of screws and most small single ovens seem to be a pretty standard size, so finding a replacement should be easy enough.
The only thing that concerns me is dealing with the electrics.
There's a thick grey cable that connects from the back of the oven to a circular junction box with 3 junctions. One goes to the oven, one goes to the hob and the other I assume leads off to the mains somewhere behind the cabinets.
Do I need to worry about current ratings for the cable or potential differences in power draw between the old oven and the new oven?
Should I get an electrician in to check or is it simply a matter or rewiring the cable as per the pics?
Pics here:
http://imgur.com/a/Mcnxa
Thanks
Pics here:
Thanks
